Discussion topic: No connection everything appears to be running as normal but no activity on tv
Message posted on 12 Mar 2025 04:31 AM
Need connection can't watch tv
Message posted on 12 Mar 2025 04:36 AM
Re: No connection everything appears to be running as normal but no activity on tv
Not a lot to go on there, but at the time of night you've posted it could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back in the morning use the below link to check to see if there are any problems or outages nearby
