Discussion topic: No broadband
Message posted on 03 Oct 2025 09:47 PM
No broadband
Hi, I had the fibre optic installed this morning and it was working fine but now I completely lost internet. No Netflix app on tv, no PS5, my ring security system disconnected and I had to close my WiFi to access the sky app so I could send that message.
Message posted on 03 Oct 2025 10:01 PM - last edited: 03 Oct 2025 10:03 PM
Re: No broadband
@Olivier4 What are you seeing lights wise on both the sky hub and your new ONT That OR fitted today. Some adjustments may be happening to your network connection. New Install with sky from an Upgrade off old copper?
It's all the same rules from sky, up until midnight off the activation day they can mess about and connections can just drop!
Message posted on 03 Oct 2025 10:06 PM
Re: No broadband
My bad, it was all done yesterday not today. All brand new with all the digging from my house to the corner of the street. All lights are on, just no internet. All that started I believe when sky remotely switched from old to new today.
Message posted on 03 Oct 2025 10:12 PM
Re: No broadband
@Olivier4 Got you, ONT not sure which you have but basic is Power and Pon solid Green light, Lan flashes as the hub sends data back and forth.
Sky hub old black one SR203 4 off solid green lights across the board, normally good sign, but can sometimes be connected but zero data is flowing, that happens switch the hub off for a couple hours and see when it reconnects what happens. All about the lights below!
