Discussion topic: No broadband/wifi
Message posted on 16 Jul 2025 05:44 PM
No broadband/wifi
I am not happy that the new gigafast broadband and WiFi are not working
Message posted on 16 Jul 2025 05:48 PM
Re: No broadband/wifi
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
