Discussion topic: No broadband red light
This message was authored by: Alberttt
Re: No broadband red light
This third time hasn't recovered and broadband has been gone for 15+ min. Cambridge
When there are broadband issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. You don't receive advance notification of this from Sky or Openreach.
Hopefully it'll be back up and running before 7am.
If it's not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
See this recently pinned thread at the top of the Broadband board from Sky about essential overnight maintenance …
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847
