Discussion topic: No broadband or wifi
This message was authored by: Miller1966
My Internet keeps dropping, can't watch TV or use laptop. Been constantly dropping all week.
Re: No broadband or wifi
@Miller1966
Try running the line test here:
If this is of no help give Sky a call to report it to them.
This message was authored by: Just+Jade
I've just moved to full fibre and mine keeps doing this too all week. Can't do anything. Sky isn't helpful and isn't updating me with anything. Tried all the online help and nothing is working!
Avatar for Miller1966
Same, just says it looks fine this end.
@Miller1966 & @Just+Jade the online checker does not pick up all faults especially if tge issue is not with the conection your hub but with tge WiFi signal in your home. If the lights on the hub show the line is dropping then call Sky to see what thry can do. If the hub stays connected but your devices are losing connection in some rooms you msy need to consider upgrading the WiFi in your home.
