Discussion topic: No broadband no way to talk to anyone
This message was authored by: Scosh
Broadband connection kept dropping out and has now been gone since last night. Service checker says it's fine but it isn't. Go round in circles and get sent to the community pages with no option to book an engineer. When you call they send you a text to do the service checker again.
please can anyone advise OTHER than the above steps that we have taken multiple times.
Re: No broadband no way to talk to anyone
@Scosh
If you call it will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
