Discussion topic: No broadband dedpite you saying there is?
Message posted on 20 Jul 2025 03:21 PM
The Internet light on my router is not lit, I've tried rebooting it several times and your tests keep telling me that it is all fine, but it's not
Message posted on 20 Jul 2025 03:25 PM
Re: No broadband dedpite you saying there is?
@Jimh6
You aren’t contacting Sky Customer Services here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
