Discussion topic: No broadband connection
Message posted on 30 Sep 2025 08:11 PM
I have no broadband connection despite everything being linked up correctly and no given outages in my area. I have reset the router three times and unplugged and replugged the line to the router to make sure connection is seated properly.
Message posted on 30 Sep 2025 08:14 PM
Re: No broadband connection
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
