Discussion topic: No broadband connection
This message was authored by: Jsenio
We have returned from work & we have no broadband connection.  We have tried turning the hub off waiting 5 minutes & re starting & still We have no connection.  Our hub box has 3 out of 4 lights on. The one not on is the Internet light. We have run your tests & they say everything is ok. The power lead has power to it.
Re: No broadband connection
@Jsenio
Not our tests, This is a customer led discussion forum where Sky customers are here to try to help other customers. You aren’t speaking to Sky Customer Services here.
As you've posted in the early hours it's worth mentioning that if there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's still down in the morning use
this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
