Discussion topic: No broadband but the system says no local issues. Reset 3 times - anyone else?
This message was authored by: Danbell23
Anyone else having issues? I'm currently trying to work of 1 bar of 4G ?
or any tips - tried the whole reboot remove wires 3X already?
Re: No broadband but the system says no local issues. Reset 3 times - anyone else?
@Danbell23
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
