Discussion topic: No broadband been intermittent for couple of weeks now nothing
Message posted on 04 Nov 2025 03:29 PM
Broadband been intermittent for a few weeks on and off all through the day no fun when you work from home today though I've got nothing not even the orange light!! Checked the checker it says broadband and Wi-Fi working I've switched the box on and off again but that didn't help!!
Message posted on 04 Nov 2025 03:35 PM
Re: No broadband been intermittent for couple of weeks now nothing
@robbieross
Use this link to check to see if there are any issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
