Discussion topic: No broadband - Saffron Walden
Message posted on 28 Nov 2025 03:09 AM
No wifi, broadband or TV (sky stream) since approx 1.30am (now 3.10am). Have tried switching on/off and disconnecting etc - nothing works. Problem must be at Sky. Terrible given I am trying to work late into the night
Message posted on 28 Nov 2025 03:12 AM
Re: No broadband - Saffron Walden
@AliceSW
If you have broadband issues between midnight and 0700 it’s likely to be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
If it's not back after 0700 use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
