Discussion topic: No broadband, Phone or TV
Message posted on 24 Jun 2025 09:47 PM
Can anyone help. Been without internet since about 3am on Monday.. Phoned Sky and ran through all the tests I had already done. Said they would phone today but didn't. Have had to use massive amounts of mobile data to watch TV and work from home.
My router has a pulsing green light that grows bigger and then goes smaller. Does anybody know why it is doing this? Is it a problem with the router?
Message posted on 24 Jun 2025 09:51 PM
Re: No broadband, Phone or TV
This explains the lights on the hubs so does it help:
Try running the line test here:
If this is of no help then you will need to give Sky another call.
Message posted on 24 Jun 2025 10:17 PM
As a general principle it's never a good idea to rely on such a callback actually happening.
Message posted on 26 Jun 2025 10:55 AM
Just an update if anyone else experiences it. The engineer says it is happening quite a bit recently. Said the information sent to the router is getting stuck. All it took was a phone call to India and they reset the signal so it can get through. Took 30 seconds to fix after he got through to them.
Message posted on 18 Jul 2025 02:41 PM
I need to speak to someone I have no broadband no tv and no phone
Message posted on 18 Jul 2025 03:12 PM
@Julie240 With none off the methods in your posting then you will have to find another way to get through to sky!
Message posted on 18 Jul 2025 03:19 PM
@Julie240 First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
