Discussion topic: No Wifi in BS20
This message was authored by: NAtkinson04
No Wifi in BS20
I am using my sky stream box and they wifi dropped out, I have used the service checker, which says my broadband is fine. I have tried using the wifi on my phone and that's gone down as well
Re: No Wifi in BS20
@NAtkinson04
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
