Discussion topic: No WiFi or phone network on mobile
This message was authored by: LouMd
I have no WiFi coverage, no house phone coverage and my boyfriend has no mobile coverage he is with Sky.  Is there a problem in Aberdeen? I am in the AB25 area?
Re: No WiFi or phone network on mobile
@LouMd
The lines will be particularly busy at present due to the damage and disruption caused by Storm Éowyn.
Regarding the mobile coverage…
Any relevant information showing on this link?
https://www.sky.com/help/articles/service-status-sky-mobile
If it doesn't he should perhaps create a question on the Sky Mobile board.
