Discussion topic: No WiFi or internet access from router, no internet light displayed and orange light at WiFi.
Message posted on 24 Aug 2024 08:56 PM
Message posted on 25 Aug 2024 01:45 PM - last edited: 25 Aug 2024 01:45 PM
Re: No WiFi or internet access from router, no internet light displayed and orange light at WiFi.
@Fubars Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.@
Message posted on 26 Aug 2024 09:10 AM
Highlander thank you for your attention.
It turns out that the openreach connection point needed to be reset by removing the power cable.
Once it had hand shaked and reset all back up again.
I did register a fault with sky as the checker wasn't finding any faults.
Still waiting for someone to get back to me...
Thanks for your advice.
