Discussion topic: No WiFi or broadband for 24 hours
This message was authored by Brittany4 This message was authored by: Brittany4
Had no broadband for 24 hours now. Done everything suggested in the app and there's nothing to say when this will be resolved.
Re: No WiFi or broadband for 24 hours
@Brittany4  First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Brittany4
Hi , I have done this and it says there is an outage in my area.
This message was authored by daveNOS This message was authored by: daveNOS
@Brittany4 If there is an outage in your area then unfortunately it may take time for Openreach to fix it, their target time is 2 working days starting the first working day after its reported but that can take longer and depends on what has caused the outage, you should call Sky to log the fault so that you are entitled to the automatic compensation scheme.
