Discussion topic: No WiFi in bedroom
Message posted on 31 Oct 2025 09:22 AM
No WiFi in bedroom
We have no wi fi signal in bedroom
Message posted on 31 Oct 2025 09:25 AM
Re: No WiFi in bedroom
@Roberta78 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
