Discussion topic: No WiFi even though it says I have
Message posted on 16 Aug 2025 06:05 PM
Help, I have not WiFi but I've checked connection and it says it's good which is not the case
There Is no light at all on the hun, I've switched off and on again and nothing please help
Message posted on 16 Aug 2025 06:10 PM
Re: No WiFi even though it says I have
@Nicci79
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
