Discussion topic: No WiFi and phone
Message posted on 22 Oct 2025 12:09 PM
No WiFi and phone
There is no WiFi or phone connection
Message posted on 22 Oct 2025 12:11 PM
Re: No WiFi and phone
@Lisa404
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 22 Oct 2025 02:04 PM
@Lisa404 when you say no phone, do you mean that there is NO Landline Phone working?
