Discussion topic: No Wi-Fi in front upstairs of the house
Message posted on 18 May 2025 06:39 PM
No wifi at all in the front bedroom upstairs
Message posted on 18 May 2025 06:50 PM
Re: No Wi-Fi in front upstairs of the house
@Tracyharry Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
@Tracyharry Where is the hub placed in respect to your upstairs bedroom, rough distance etx, and which sky hub do you have!
