Discussion topic: No Wi-Fi connection in the main bedroom
This message was authored by: Skywifipoor
I live in a bungalow the problem being is no Wi-Fi operates fully at the opposite end to the router the lounge is ok the main bedroom is negative to intermittent may work but nothing fully active we're the routers placed
Re: No Wi-Fi connection in the main bedroom
@Skywifipoor Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes including many bungalows. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
