Discussion topic: No Sky Q internet connection on main box flashing amber I’ve switched off, reset and pressed the WPS
This message was authored by Crowsonk This message was authored by: Crowsonk
I have reset, turned off and pressed WPS. This keeps happening frequently and getting really frustrated.
Crowsonk
Re: No Sky Q internet connection on main box flashing amber I’ve switched off, reset and pressed the
It keeps saying no network connection but my service status is fine etc
@CrowsonkPressing the WPS will do nothing really for you unless you are trying to connect a device that is connecting via Wi-Fi to your network that is what the button is for. If you have a flashing internet light and it is amber it is trying to connect back up. If this keeps happening then you do have an issue.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
This message was authored by Voller This message was authored by: Voller
My sky box keeps freezing
my WiFi doesn't work around the house and I've purchased additional boosters too.
my router has an amber flashing light
@Voller Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
