Discussion topic: No Internet since yesterday - test says it is good - no light or orange light on hub
Message posted on 25 Oct 2025 10:31 AM
Would like to get it working
Message posted on 25 Oct 2025 10:37 AM
Re: No Internet since yesterday - test says it is good - no light or orange light on hub
@Confused99
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
