Discussion topic: No Internet or WiFi but green say wifi on no geee light for Internet. I have done all usual tricks
This message was authored by: Alliso
Have unplugged etc try reset nothing 4 times reset on Box nothing again.  This upset my son who relies on Internet taking  out on me I need fixed ASAP
Re: No Internet or WiFi but green say wifi on no geee light for Internet. I have done all usual tri
@Alliso if the connection is still down this morning and the connection test in the My Sky app run over a mobile connection does not tell you Sky are aware of a fault in your area call them and report it. They will get it fixed but it can take a couple of days and in some cases far longer it depends on the cause.
Your son needs to learn to accept not everything works 100% perfectly 100% of the time and things simply break it isn't personal or his mother's fault its simply bad luck.
Avatar for Alliso
Unfortunately my son has adhd mental age of young child he 22 he doesn't Understand
