35
This discussion topic is read only This discussion topic has been answered Discussion topic: No Internet on full fibre
This message was authored by: Svyas
No Internet on sky full fiber since 30 mins ,test show everything looks good ,very deceptive my sky app
Re: No Internet on full fibre
@Derhyce
See my post immediately above yours. If it's not back by 7am use the below link to check to see if there are any broadband problems or outages nearby
This should determine if there's an identified fault affecting multiple households.
Locked
This message was authored by: John63
Sky Broadband Issues
No WiFi or Internet connection, although the broadband test through MySky shown no issues with network or WiFi?
This message was authored by: kezzabel
Re: Sky Broadband Issues
Got the exact same problem
This message was authored by: Nichola2
Mine is the same, are you back up yet?
This message was authored by: PDRD
Same problem here
This message was authored by: Mac253
Mine is down as well.
Did a check on Sky and it's saying everything is fine. But it's not
This message was authored by: AbigailBremner
having the same issues. Ran a internet connection test doesn't show any faults.
Same here. Power and wifi lights are green, voice is orange and internet isn't on. Down multiple resets, troubleshooting that the website advises. Nothing has worked and highly annoying that the Sky app keeps saying that everything is all connected and working fine.
This message was authored by: chaoyan
same problem. no internet after 12:15AM
This message was authored by: Cheryllouise
I have the same issue rubbish app stating no issues but no connection for around an hour now!
This message was authored by: Chansmier
Same problem here
This message was authored by: Mix0182
Same here 1:24 am
Exactly the same here been trying, turned off from the wall. Sky app checker says no problems but still connected without Internet at 1:24am
This message was authored by: Dart2
same issue. No internet. Test show everything is fine. Did anyone can sort it out?
This message was authored by: scattynat
Sky Broadband Down
I can see others complaining, same here. Broadband went down about 0030hrs, tried reset etc and nothing worked then friend called and his was the same, we live Dartford & Bexleyheath respectively so not sure if this is London & South East or all over? But frustrating for the service status app to keep telling you everything is okay when clearly it's not and no-one you can contact to ask for an update.
Locked
