Discussion topic: No Internet connection on router as Internet light is not lighing up at all
Message posted on 04 Jan 2024 03:30 PM
No Internet on router the Internet light is not even lighting up and I have restarted the router and does not work even when I do that
Need help with it
Message posted on 04 Jan 2024 03:32 PM
Re: No Internet connection on router as Internet light is not lighing up at all
@Maylb17 run the connection test in the My Sky app over a mobile connection as thst will tell you if therecis a known fault affecting your line. If there isnt you need to call Sky to report the fault.
Message posted on 04 Jan 2024 03:38 PM
Can't got no credit to call them
Message posted on 04 Jan 2024 04:21 PM
I've escalated your post to Sky, look out for a message on the forum so you cant chat with them
Message posted on 04 Jan 2024 05:01 PM
Thanks for escalating this. We’ve sent @Maylb17 an invite to chat.
Lisa - Sky Tech Team Expert
Message posted on 06 Jan 2024 11:39 AM
No internet connection
Hi i have a new router but still no internet connection
Message posted on 06 Jan 2024 11:44 AM
Re: No internet connection
Was the router sent out as the result of the chat invite that was sent to you?
Message posted on 06 Jan 2024 11:49 AM
The new was sent out to replace the one I had as my internet light was not lighting up
My internet connection is still not coming through
Message posted on 06 Jan 2024 11:50 AM
Still have problems
Message posted on 06 Jan 2024 12:18 PM
Is the chat invite still active? There has been no update so it may still be possible to speak to the Messaging Team.
Message posted on 10 Oct 2025 09:44 PM
SKY hub router internet light not working..states we have WiFi but no internet.
Cant contact SKY as have no internet..
Not sure why not working..any advice..
Message posted on 11 Oct 2025 05:55 AM
@Anne146
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
Message posted on 31 Dec 2025 12:01 PM
I only have amber light on my sky box
No internet light on my sky router
