Discussion topic: No Internet connection in ethernet cables
Message posted on 29 Apr 2024 11:26 PM
I'm new to Sky today, I have a Sky Hub router which is connected to the fibre wall box via Port 4 as per the instructions.
I have three of my Cat 6 ethernet cables servicing TV's and a Gigabit switch for cameras etc that worked perfectly with Vodafone until the switch over.
I have everything in the Sky hub correctly but I am not getting any juice at the TV's or Gigabit switch. There is lights flashing on the back of the Sky hub where the ethernet cables are so it's obvious the hub is recognising them.
So I basically I need to get supply out to my ethernet cables, I know it's not a damaged cable as I'm having the same trouble with all three.
Anybody any ideas?
Message posted on 30 Apr 2024 08:15 AM
Re: No Internet connection in ethernet cables
@Doco1 first point check your ethernet switch is inependently powered and working. Sky hubs unlike a few other routers does not provide power over ethernet so the seitch needs its own piwer supply. Secondly check what type of switch you have, the hub should work with simple unmanaged switches but if your switch is the more compkex type which is managed you may have to change its configuration to work with your new router.
Message posted on 04 May 2024 10:13 PM
It's not the ethernet switch that is the problem.
Fom my modem I have three outgoing ethernet cables, one to my TV, another to my Sky Stream and the third to my switch. All three devices aren't getting connection by ethernet which leads it to an issue with the modem?
It can't be the Cat6 cables as all three were working perfectly previously
