This discussion topic has been answered Discussion topic: No Internet connection and all test come back as no issues
Message posted on 28 Aug 2025 01:04 PM
I have no Internet connection and have done have done all the tests and they come back with no issues, the 3 lights are green on the feeder box to hub, and the hub box is giving a white light, have tried WPS button and resetting the hub multiple times still no Internet
Message posted on 28 Aug 2025 01:05 PM
@Frad
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
If you’re still having problems you may need to contact Sky to report it.  The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
@Frad
