Discussion topic: No Internet again, sky checker says everything working
This message was authored by: Kelvin_B
Sky speed test says everything is ok even when my Internet light is an error, this issue keeps arrising. Please rectify
Re: No Internet again, sky checker says everything working
@Kelvin_B wrote:
Please rectify
@Kelvin_B
Hi, in case you’re not aware you aren’t directly contacting Sky Customer Services on here. We are mainly customers trying to help other customers.
Use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
Avatar for Kelvin_B
Level 0 icon
I fully appreciate that, I have don't the mentioned tests on the app and everything says it's ok. Not outages seen.
The app however guided me here to start a discussion if I needed more help. 🤦
Good old sky, deflect attention and hopefully it will resolve itself.
Many thanks
Avatar for Kelvin_B
Level 0 icon
Internet has been restored 🙏 how long until the next outage is my concern.
