Discussion topic: No Broadband or WiFi connection on sky Q hub
This message was authored by: Kas46
Re: No Broadband or WiFi connection on sky Q hub
@Kas46 use the on screen instructions to reconnect the Q box. If it still wont connect to your home router then give Sky a call as they can send an engineer out if they cant fix the problem overvthe phone.
Avatar for Kas46
Thank you so much. All sorted now.
kas@46
