Discussion topic: No Broadband after moving home. Help!
Message posted on 22 Jun 2024 09:46 AM
Message posted on 22 Jun 2024 03:09 PM
Re: No Broadband after moving home. Help!
@JustinTanLH Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
This should give you some information about your connection and any directions on what the possible issue could be.
Message posted on 22 Jun 2024 07:38 PM
@Highlinder Unfortunately the troubleshooting didn't help and all it did was taking me around a loop with all the tests. I got in touch with SKY and they will send an engineer out again, possible an external fault. Should that be picked up by the engineer just 3 days ago surely!? I'm considering leaving SKY because of this.
Message posted on 22 Jun 2024 08:58 PM
@JustinTanLH Best to let them try to fix it and then you can see what your options are.
