Discussion topic: No Broadband. Not able to contact Sky . I wish to speak to them as I am unable to reset. Any contacI
This message was authored by: Decosball
See title
Re: No Broadband. Not able to contact Sky . I wish to speak to them as I am unable to reset. Any con
@Decosball
Your post isn't clear… no broadband as in its crashed?
If so use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
@Decosball You would need to call sky and use the contact us, but easiest to dial 150 from your landline or a sky mobile!
