15
This discussion topic has been answered Discussion topic: Next door has sky broadband but i cant get it
This message was authored by: Stu129
Hello.
I've tried to get sky broadband last year.
At the time I was told that sky can't deliver broardband to my address even though my next doir has/had it.
I complained and sky raised a ticket with openreach.. a week later sky phoned up and said all sorted now. But wait a month for the address database to update.
I couldn't wait that long so went with another supplier.
I am looking for more broadband now and have the same problem. The only differance is that on the address finder tab it has now got my street but no house numbers. It just says street record, then the street address and postcode.
Can any one help?
This message was authored by: cookiemonsteruk Answer
Re: Next door has sky broadband but i cant get it
@Stu129
Shouldn't have any issues
You may need to call sky to place the order or at least get an explanation of whats happening
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
Avatar for Stu129
I forgot to also say we have sky tv already.
@Stu129
Enter your full address in the link below and post the table and notes after removing your address from the image
Avatar for Stu129
This might sound daft but I can't work out how to upload a ss of what you have asked.
Any instruction would be wonderful.
Avatar for Stu129
I've worked it out im only level 1. I need to be level 2 or above to post pictures 👉😃
Is there a way of doing this in a timely way?
@Stu129
When you post a reply there are a series of icons along the top .  Click the one that looks like a picture/photo frame which should bring up your gallery.
@Stu129
Try copy and pasting the text
Avatar for Stu129
If only it was that easy. It won't let me copy and paste the information ... I will try and pick out what ever info you want if you like.
@Stu129
Info along the top two rows vdsl and whether sogea columns are available or waiting list also whether wbc fttp is showing
Avatar for Stu129
@cookiemonsteruk wrote:
@Stu129
Vsdl range a . High 70.4 low 49. High 18.9 low 12...... down stream 44....wbc unavailable...sogea exception. VDSL RANGE B high 61.6 low 44...high 18 low 10.8...down stream 35...wbc unavailable...sogea exception.
wbc fttp is showing...upto 1000...upto 220...data avaliable...fttp 1 stage.
@Stu129
Then you should get full fibre . Are you using the exact same address for both the wholesale checker and sky
What do the notes say below the table
Avatar for Stu129
Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
Avatar for Stu129
I had to email myself the ss and then copy and paste.
Avatar for Stu129
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate (Mbps)
Downstream Handback
Threshold(Mbps)
WBC FTTC Availability
WBC SOGEA Availability
High
Low
High
Low
VDSL Range A (Clean) help
70.4
49
18.4
12
44
Unavailable
Exception
VDSL Range B (Impacted) help
For VDSL Range B the term "Impacted" is a line which may have wiring issues (e.g. Bridge Taps) and/or Copper line conditions.
68.6
44
18
10.8
35
Unavailable
Exception
G.fast Range A (Clean) help
Unavailable
G.fast Range B (Impacted) help
Unavailable
Featured Products
Downstream Range (Mbps)
Availability Date
FTTP Install Process
WBC FTTP
Up to 1000
Up to 220
Available
1 Stage
Other Offerings
Availability Date
VDSL Multicast
Available
Exchange Product Restrictions
Status
FTTP Priority Exchange
Y
WLR Withdrawal
Y
SOADSL Restriction
N
@Stu129
