3
This discussion topic has been answered Discussion topic: New sky hub for full fiber
This message was authored by: alcaz
I am upgrading to full fibre from superfast. I have the new hub/router but do not get connected until Tuesday. If I change the router name and password to the same name and password used by my old router, will all the connected items still connect instead of having to go to each one and change the connection?
This message was authored by: Highlinder Answer
Re: New sky hub for full fiber
@alcaz  That should work without issues.
@alcaz
Note that if it's the white Max Hub, this is done through the My Sky app, and you may find the appropriate tabs aren't yet populated there.
Avatar for alcaz
Level 2 icon
Not the white router mines the sr 302
