3
This discussion topic has been answered Discussion topic: New hub do I need to reboot my iPad
This message was authored by: Donna158
I have just received an upgrade to a new hub  do I need to do anything to my iPad so it recognises the new hub?
Re: New hub do I need to reboot my iPad
@Donna158
By default any new Hub will be broadcasting a new network name with a different password to the one you had before.
@Donna158
@Donna158
You would need to get your iPad to find your new Wifi neywork then connect to it using the password that came on the small card. You can do this via Settings > Wifi on the ipad - just select your new Wifi name.
Avatar for Donna158
  1. Thank you for your help 👍👋🩷
