Discussion topic: New cable?
This message was authored by LouiseH94 This message was authored by: LouiseH94
New cable?
I currently have sky superfast, I’m getting ultrafast installed in a few days. When the engineer comes to swap the routers, will they also need to replace the cable coming into the house?
Re: New cable?
@LouiseH94
Openreach will either run a fibre optic cable underground or overhead and connect it to an ONT inside
Both will usually be done on your activation date
Re: New cable?
@LouiseH94
Confusingly, some Ultrafast can be delivered over existing copper phone lines using G.fast technology: Sky only supplies the 150Mbs Ultrafast 1 product this way, and only in areas where Openreach G.fast infrastructure has been deployed (elsewhere FTTP is used). Ultrafast 2 (500Mbs) and Gigafast (900Mbs) is always over purely optical cabling.
