Discussion topic: New broadband equipment won’t connect to internet
This message was authored by BeckyFf This message was authored by: BeckyFf
I upgraded my sky contract at the start of august to include sky broadband superfast and.l broadband boost and I was sent a new sky broadband hub to replace my sky Q hub.
The new sky broadband hub won't connect to the internet (light stays amber). I've tried all the troubleshooting suggestions. The old sky Q hub still works fine but obviously I'd like to use my new upgraded package. It's past the activation date.
Can't get through to anyone to help... what can I do!
Re: New broadband equipment won’t connect to internet
@BeckyFf
When is/was your activation date?
BeckyFf
@cookiemonsteruk @There was no date on the box but my contract states that services are expected to go live between 16/08/22 and 20/08/22
@BeckyFf
Did openreach install one of these
Where is your router cable plugged into? A mastersocket or an ONT above
BeckyFf
No. Just plugged into this...
(that's the q plugged in for now while I try to find a solution). There was no mention of anything else being fitted) @cookiemonsteruk
@BeckyFf
And is the other end of that cable a purple plug plugged into the purple port on the router
BeckyFf
Yes, I was using the black cable
supplied, plugging the white end into the master socket and the purple end into the purple port in the hub.
(in my pic is a grey cable which is for the sky q hub. When I was trying to setup the new equipment this was unplugged but for now
ive reconnected it so I can try and find a
solution to the amber light)
BeckyFf
@cookiemonsteruk forgot to tag you in the last post. Thanks for your help btw!
@BeckyFf
Is there any info in "your orders" on your my sky app or sky.com account?
BeckyFf
@cookiemonsteruk no nothing. In orders it says no orders in progress.
The only info I can find is in the contract summary which was where I found the activation dates and those look like standard terms. I've been paying for this since 05/08/22 didn't work before I went on holiday so thought it might be an activation issue but it's still now working now I'm back
@BeckyFf
It does sound like a failed activation.
Call sky on 150 from your sky landline or sky mobile or
zero three three three seven five nine one zero one eight from any other phone
Or if in Ireland
Call sky ireland on
08.185.00.27.2
Remove all the full stops
If asked is this about sky mobile say no
When asked if you would like to receive an sms say no
When asked do you want to hang up and follow the link say no
When asked about the nature of your enquiry say something like "failed activation" or "broadband not working"
Don't hang up but persevere until someone answers
BeckyFf
@cookiemonsteruk Thanks, I'll try that
@BeckyFf
Keep us updated 👍
BeckyFf
@cookiemonsteruk got through on the phone... sky think it might be the equipment and are sending out an engineer
