3
This discussion topic has been answered Discussion topic: New Sky router won’t connect to printer or phone
This message was authored by: KJay11
Hello new Sky broadband router to replace old router received. Cannot connect PC or iPhone to HP printer that is over 10 years old but was working fine with old router. Can anyone help please?
Re: New Sky router won’t connect to printer or phone
Your new router will have a new wireless name so you need to set everything up again by getting your devices to search for all available wifi networks then connect to your one by using the password that came on the little card. The network name is also on it as it will start with SKY.
This message was authored by: absmo
My I phone keeps coming up with this message I have new router
This message was authored by: Old+English
I had a problem trying to get on a site because of private relay it happened after an update where I pressed something, go to settings tap on your name then onto iCloud you have the option to turn private relay on and off turn it off and you should be able to get on as normal I found it again by accident as it was driving me nuts...
