Discussion topic: New Sky broadband no connectivity on one side of house
This message was authored by: liabri
I just had my broadband connected and they had to put the router on the other side of the house to where all our devices are as this is where they put the fibre cable. I now little little to no wifi on the main side of the house and need a bosster/pod.
Re: New Sky broadband no connectivity on one side of house
@liabri You would be advised to look closely at the moving the sky Hub to the position that you had before especially if it was working fine, the cable supplied by sky for connecting to the new ONT is short, but a longer cable off the length you need to move the hub would be far better to do then trying to boost signal! See the link but ignore the title for the link and this is part
Where you put your hub is really important!
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
