Discussion topic: New Sky Hub internet not working
This message was authored by: Olly16
Recently moved into a new flat and purchased the sky hub broadband, activation date was few days ago and service checker says everything is okay but no green light on the internet?
Tried resetting and listening to the advice from Sky but no luck? any help would be appreciated
Re: New Sky Hub internet not working
@Olly16 What do you have, and what have you done! Also confirm that you have recieved the activation off the system text from either OR or better still from Sky!
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
This message was authored by: Jynxy
Which broadband service did you order?
Sky Superuser - If i have helped you please mark as solution to help others. Thanks
1x Sky Q Silver - 1x Sky Wifi Max Hub - SKY Fibre Ultrafast.
Avatar for Olly16
Sky broadband super fast
Do you get a dial tone if you plug a phone in the back of the router, or directly into the socket ?
Do you get any lights at all on the router?
