Discussion topic: New Sky Broadband 5 times slower than previous provider Plusnet
This message was authored by: janmnnss
Switched from Plusnet to Sky Broadband because Plusnet kept having outages that lasted almost a year and it's only been 3 days since my Sky Broadband was activated but it's extremely slow. With Plusnet on the top end I was getting 80mbps download with a guaranteed speed of 66mbps. With Sky the absolute max it will go to the hub is 15mbps. Over 5 times slower than before. Below I have attached the router statistics from my Sky Hub and the results from the BT wholesale line test. Thanks for your time.
Re: New Sky Broadband 5 times slower than previous provider Plusnet
@janmnnss
I would imagine those outages you had with Plusnet were because your line has major problems. When switching ISP within the Openreach remit you are essentially keeping the same line so any problems will just follow you. Your router stats show a major line fault so you'll need to contact Sky and report the fault, however they usually wont allow you to report any faults until you've been through the 14 day 'stabilisation' period
I am NOT a Sky Employee
Avatar for janmnnss
Okay thanks for the reply is it the "noise margin" that indicates a fault in the line? So I know what to refer to when I contact them after the stabilization period.
@janmnnss
Yes your noise margin should be between 3 - 6dB.
You can see that your router is receiving 16.4mbps on the downstream whereas the check you posted from the BT Wholesale site states that the minimum handback speed for an impacted line should be 60mbps. So yours is way below what it should be.
What is confusing me though is why your upload seems to be limited to 10mbps which would suggest you are on the lower tier Superfast package. Which package did you take out? Are you on some sort of Benefits based package?
Avatar for janmnnss
@jamesn123 It was done over the phone at the same time as getting them to replace the Sky dish and change all the boxes and the guy on the phone just said it was the "fastest available to you" in regards to the internet. I told him the speeds we were getting before but he wasn't the most helpful. I didn't realise not pressing him more would result in 5x slower speeds though.
@janmnnss
Okay bit odd but either way you need to get the fault fixed before anything else is looked at.
Avatar for janmnnss
@jamesn123
Yeah I probably should have booked it online in retrospect because I find that easier but thanks for your help. I will just wait out the stabilisation period and then contact them to report the problems I'm experiencing.
@janmnnss
I am happy to escalate your post to a Sky advisor so you can chat to them on the forum, but I suspect they will end up telling you that you have to wait out the period.
Avatar for janmnnss
@jamesn123
Okay yes please I would appreciate that! It is worth a try to see if we can get the ball rolling atleast.
@janmnnss
Done, look out for a message on the forum, you should see a chat bubble popup once the advisor has posted here that they've initiated the chat.
Avatar for janmnnss
Okay I will keep my eyes pealed. Thanks again!
This message was authored by: Lisa-P1987
Thanks for escalating this. We’ve sent @janmnnss  an invite to chat.
Lisa - Sky Tech Team Expert
Avatar for janmnnss
Support was absolutely useless. Telling me there is no issue with my line and that 15mpbs is somehow a normal and acceptable speed despite the obvious facts. Will be cancelling my Broadband package and going elsewhere. Will be moving to BT who offer 67mbps guaranteed speed at my address. Unlike the liars at Sky who insist the max available is 15mbps.
@janmnnss the issue will move with you as it is the line which is the problem is not the ISP. In due course Openreach will update the database to reflect the true speed the line can support. In the past Openreach would do work to improve lines but now they are switching to fibre they are very reluctant to spend money repairing lines.
If moving go to a supplier who doesnt use the Openreach line like Virgin Media or a mobile provider.
@janmnnss
Unfortunately the Universal Service Obligation is for a whole 10Mbs inbound and 1Mbs outbound: while a connection remains above that there's no actual obligation to deliver anything better, as long as the ISP permits an early exit without penalty.
