Discussion topic: New Customer - Sky Max Hub VPN No longer works
This message was authored by: antarctica98
We joined sky on the 8th Oct and my works VPN connection was totally fine until the Friday 18th Oct, from some Googling it appears the issue is that Map-T 8:1 sharing has now been enabled and I require it to be 1:1 to get a real/usable external ip address (I have disabled sky sheild and enabling upnp as suggested had no effect as its still 8:1) so VPNs can connect.
@Chrisee , @-rpnz- @TimmyBGood tagging you here as i see you have been able to help others; I would be most grateful if this could be escalated to the relevant people please! else will need to cancel before end of cooling off period expires
thx for your help
-Brett
This message was authored by: Lisa-P1987
Re: New Customer - Sky Max Hub VPN No longer works
Lisa - Sky Tech Team Expert
