Discussion topic: Network Dowloand speed only 22.50
Message posted on 06 Sep 2024 06:00 PM
Message posted on 06 Sep 2024 09:48 PM
Re: Network Dowloand speed only 22.50
@M_STAVELEY Are you measuring this speed via Wi-Fi or a wired connection?
Message posted on 08 Sep 2024 08:49 PM
@Highlinder is a wi-fi connection
Message posted on 09 Sep 2024 08:16 AM
@M_STAVELEY If you are getting 22.5mb/s on a Wi-Fi device what are you getting on any wired devices connected to the router and if you get 75mb/s to the router then there is always a drop in the speed with all devices looking for a bit of the at 75mb/s.
Plus Wi-Fi will be the slowest device to measure any speed from. If you can do the same test on wired that would give you a better indication of what speed you are getting.
