19 Apr 2022 06:18 PM
Hey All,
Wondering if I can get some help... Im due to switch across to Sky 900mb FTTP on Monday... Ive ordered Netgear Orbi WIFI 6 Mesh RBK853 and its arriving on Friday.
Anyone any experience of these? Ive ordered a 3 pack... quite expensive so I am expecting that they are great... do I need to still use the Sky Router for these?
Any advice appreciated.
Robert
19 Apr 2022 06:23 PM
You could use them alongside the sky hub but they would just be expensive access points
I do believe in router mode they should be able to directly connect to the ont with the rbr853 authenticating and the rbs853's meshing
19 Apr 2022 06:26 PM
It would be great if they connected without the need for the Sky Hub (removes the extra point for slow down).
When they arrive Ill have a look and see if I can get it authenticating with the ONT as I can potentially test on my BT FTTP before Sky take over.
19 Apr 2022 06:31 PM
In the uk sky uses a different authentication (dhcp option 61) to BT . In Ireland sky uses the same ie pppoe. But i am sure they will work with all isp's
19 Apr 2022 06:32 PM
Im in UK... Ill read up on the Orbi and see if I can use the corrrect authentication setup
18 May 2022 03:37 PM
Hi @Robertb82 - curious if this worked for you? I am due to receive 900mb install in a week and hadn't realised in advance that (unlike virgin) you can't "modem mode" the sky hub. I have the 850 series orbi and keen to know if this works direct to the ONT.
14 Nov 2022 03:12 AM
Any update on this?
16 Dec 2022 03:08 PM
Why not ? Just turn the Wi-Fi ap and broadcast ssid in both the 2.4 and 5 GHz settings
