Discussion topic: Need to know which UDP Ports are open on home router and add extra if not supported
Message posted on 21 Dec 2023 02:46 PM
Hi! Have a device for work that is not working on broadband. Work IT Support has asked me to check that specific UDP Ports are open. Is there someone I can talk to to check this please? 40 mins on phone with Sky Broadband Support got me nowhere.
Message posted on 21 Dec 2023 03:00 PM
Re: Need to know which UDP Ports are open on home router and add extra if not supported
Generally speaking, all ports are open outgoing and only those you port forward receive traffic unless invited in by an outgoing connection.
Message posted on 21 Dec 2023 04:10 PM
OK Great, thank you. And I should only need to follow this process to port forward on the one relevant device for it to work?
https://helpforum.sky.com/t5/Broadband-Talk/How-to-set-up-port-forwarding/ba-p/2662260
Message posted on 21 Dec 2023 04:12 PM
That is the correct document for doing port forwarding to a LAN device and inviting the traffic into your LAN network.
Message posted on 21 Dec 2023 04:15 PM
Thanks again! Is there a document for non-LAN devices?
Message posted on 21 Dec 2023 04:17 PM
You don't need to do anything for an internet WAN device the traffic is allowed outgoing by default.
Message posted on 21 Dec 2023 04:21 PM
Just remember for everything to be allowed out don't block the traffic DNS-wise with Sky broadband shield. There is a document on adjusting the Sky broadband shield on the Sky site.
