Discussion topic: Need to connect direct to router but product in other room
This message was authored by: Mattn09
I have a dvr that needs to be connected direct to the router. However my router is in a different room and I cant move the dvr as it is connected to wired security cameras. With BT I connected to one of the mini connectors via ethernet cable. Is there an equivalent with sky?
Re: Need to connect direct to router but product in other room
@Mattn09
Best option are wifi enabled powerline adapters which transfer lan packets via the electric wiring . Not sure what model of bt connectors you have but i had bt powerlines in the past and they worked with other isp.  Also if its the white bt home discs you have they should work with sky
