Discussion topic: Need to change 5GHz wifi channel to lower channel
This message was authored by: AndyT6
Laptop cannot use high wifi channels but hub selects them I need to restrict channel range but all settings are inactive!
Re: Need to change 5GHz wifi channel to lower channel
@AndyT6 unfortunately that is not possible on either the Sky Max or Sky Gigabit hubs there is no way to select wifi channels used.
