18 Feb 2025 10:11 AM
Hi,
I am needing to change my 2.4Ghz WiFi channge on my Gigafast connection as it picking the wrong one, however when I look at the settings on the router and Sky App, I am unable to change this.
As the screenshot below says, it selected the best channel and is being managed automatically, not allowing me to change it.
Also you can see below the WiFi Analyner when I am right by the Router/Hub and it can get worse as I move away from it.
It also recommends channels 3, 4, 8 and 9.
Regards,
Garry
18 Feb 2025 11:15 AM
Posted by a Superuser, not a Sky employee. Find out more@GazCBG yyou cannot manually change theWiFi channel the white Sky Max hub uses. The hub should pick the best channel automatically butvrestarting the hub may make it choose a better one.
18 Feb 2025 01:19 PM
That did it, now on channel 1
18 Feb 2025 05:57 PM
Hi,
Can it also be changed my disable and re-enabled WiFi on 2.4Ghz do you know?
Regards,
Garry
