Discussion topic: Need to book engineer to fix physical broadband connection into house
This message was authored by GKW69 This message was authored by: GKW69
Internal fibre connection to box broken and need engineer to fix, how to arrange this via Sky
Re: Need to book engineer to fix physical broadband connection into house
@GKW69 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
